Foam in Q45 Chassy
1qckser
Car: my wife, daughter, q45T,G20T,SE-R
Foam-Filling the ChassisIn any high-performance car, it is impossible to make the chassis too stiff. The stiffer the chassis, the higher its natural frequency, making the energy imparted to it by bumps less likely to excite the body's structure. A stiffer chassis enables the use of stiffer springs and shocks without hurting the ride. This is because a stiff, non-flexing chassis transfers more force into the suspension where it can be dissipated by the springs and shocks instead of transferring the force to the occupants. A stiff chassis is also more responsive to roll rate tuning for balancing understeer and oversteer. This is one of the reasons why automotive engineers are continually investigating ways to stiffen chassis without adding weight.
In a final bit of reengineering to stiffen the body, we injected the chassis with catalyzed rigid structural polyurethane foam. Structural foam, in the 2 lb per cubic foot density that we used, can stiffen chassis members up to 40 percent.
Higher densities of foam can increase stiffness by up to 300 percent. Since we cannot retool custom parts to redo the Z's body, we figured that this would be an excellent, low-cost way of greatly increasing chassis stiffness. Injecting foam is not a new technique for chassis stiffening. The Infiniti Q45 uses this sort of foam in some of its chassis members to increase stiffness, as do a few other premium cars. In fact, the foam we chose is the foam recommended to repair damaged Q45s.
To get the correct foam for our project, we contacted Art Goldman, Foamseal's automotive product manager and author of an SAE (Society of Automotive Engineers) paper on the use of structural foam for the stiffening of automotive unibody structures. We used Foamseal's two-component foam kit, p/n 11-22 to fill the main members of the chassis. Like we mentioned earlier, Foamseal is the supplier that I-CAR, a national certification group for quality auto repair, recommends for the repair of damaged, foam-filled chassis. The Foamseal kit uses a two-part catalyzed polyurethane foam, which quickly cures into rigid, waterproof, closed-cell foam. To prep the car, we carefully masked off all painted areas anywhere where the foam could drip. As this sort of foam is a thermosetting catalyzed plastic, we realized it could be icky if it spilled on paint or any part of the car's interior. This foam is nasty stuff. It is impervious to all known solvents and cleaners.
Rubber gloves must be worn. Get some of it on your hands and it will stay there for more than 3 weeks--don't ask how we know. Do not get this stuff on your paint. Wear old clothes; we ruined ours while learning how to handle the product. We injected the foam into the rocker panels and frame rails of Project Z through existing bolt and drain holes. When injected, the foam reacts like shaving cream and quickly expands to fill the empty space. You can judge how much foam to add by watching its expansion progress through some of the holes. Once injected, the foam expands and begins to cure in about a minute so you need to work fast and plan how you inject the foam before you start.
The life of the foam kit is limited to a few hours once the seal is broken. We filled all of the Z's unibody frame members using five foam kits. When foaming a chassis, you must remember the wires and other lines that pass through the chassis must be relocated or they will be entombed forever.
We were amazed at how this simple procedure improved the performance of the car. The chassis now almost feels like it has a roll cage. A sloped driveway can be driven up sideways with nary a creak. Even though the Z already has a pretty tight chassis, it feels more solid. The ride has improved and road noise has been reduced noticeably. We bet that the car will be even more responsive to chassis tuning measures in the future. If you are a slalom racer, a road racer, have a lowered car or even just want a smoother ride; foaming is a worthy, easy-to-do modification. Foamseal has foams in densities as high as 10 lbs per square foot if you desire to make things even stiffer.
Do not--I repeat--do not attempt to use cheap, hardware-store canned foam. This is not the same thing, and if injected into your chassis, will form a gummy mass that won't dry. Foamseal foam is a professional grade foam, which although it is a little unforgiving to cleanup mistakes, has superior mechanical properties and catalytic curing so it will dry even in an enclosed space.
These changes are continually improving and refining Project Z as we eagerly await our motor. We still have some more parts that we will install and review in upcoming issues. Stay tuned, the best is yet to come!
The precision-ground washers shown here are used to control the flow through the piston. By using different washers stacked in different configurations, they can be tuned like little round leaf springs to hold the valve closed under different pressure and velocity conditions.
An assortment of Stillen parts are holding together the back of our Z. The HICAS eliminator (top) gets rid of the rear-wheel steering, the Stillen rear strut tower brace adds some much needed rigidity in the weak hatch area, and finally, Stillen rear adjustable upper control arms allow us to get rear wheel camber back where we want it, despite our low ride height.
The Tein upper shock mount shown here eliminates the stock squishy rubber mount, replacing it with a spherical bearing. Also show are the external damping adjusters. The red knob controls rebound damping, the blue knob controls the compression damping.
The Foamseal Two Component Foam Kit consists of two easy-to-use aerosol containers of material with a nozzle and a mixing chamber.
As the foam cures, it expands with the excess coming out of the holes where it was injected. Note how it is important to mask carefully. If you accidentally use too much foam, you could have much more coming out of the holes than we did. If it gets in the carpet, it will never come out.
PalmerWMD
Car: 2004 350Z
1quick:
Is this your project car?
Fred...:)
1qckser
I wish it was, its part of an article I found while searching for stuff for the Q, these guys are building a sick 300 TTZ, I will see if I can find the article again, I also have a clip of my exhaust sound if your interested. :)
I am - I'm planning a few exhaust mods of my own soon!
docsmile71
yeah, me too. Let me hear your exhaust.
1qckser
Ill get it to you tommorow, i just gotta download it, please send me your email addresse, thanks
1qckser
Doc how close are you to CT? me and Qship are about 1 hour 15 minutes from Boston.
[email protected]
Where did you get your resonators? Brand?
(and what did you do with the APC sticker that came with those tips, mister?:D)
1qckser
I placed it in the circular file:D , the resonators are from my local exhaust guy, but you can use the normal glass packs because they also have a smooth perforated core, the glass packs are about $15 each, the tips are really nice ill get ya a close up in the file I send ya today. I di however hear a Q with the ultraflow and it sounded good, however if you can get it done the way I did you will save a great deal of cash over going with the ultraflow, plus they sound almost the same.
1qckser
AZ I just sent ya the clip, i sent 2 of them, sorry for the quality, im new at the video stuff.
