SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Mon Nov 17, 2003 10:46 am
How does heat dissipate?
Is the foam fill a hard compound?
What happens to deflection with a foam filled/solid tire?
How does a foam filled tire react when the vehicle load is suddenly shifted to two of the wheels? (braking or hard turn-in)Since the tire flexes less, the tread is in effect over-abused, and will wear out extremely fast, or cause sliding/skidding. Might as well air up your tires to 50psi and go ice skating with your car.
How do you change the worn out tire that is foam filled? With a sawzall!! Would you feel comfortable with a tire guy taking his sawzall to your custom wheels? I wouldn't.
Then it adds unsprung weight. Then, to find any benefit, you need a car that will travel in excess of 150mph and up to make use of the safety margin that the tire guy is basing his sales pitch on.
All in all, I say steer clear. But just for trivial purposes, could you ask your tire guy how he dismounts a foam filled tire after it has worn out?? I've tried to articulate above, but a foam filled tire cannot flex as intended, putting great fatigue on the tread blocks, causing extreme heat, wearing the tire out quickly. Then you have to buy new tires, and watch the tire guy cut off your old tires with a sawzall... or so I'm told. Too many unknowns...
