Superdave54 wrote:I discovered that the paint on the body door sill opposite the bottom door weather strip was getting chewed up by the grit that was driving itself it there off the front tire despite the mud guards. This was happening on the front and rear doors.
I bought some EPDM Rubber automobile weather strip that is about 1/2 inch square with pressure adhesive on one side.
After getting the area clean, I crawled underneith with the doors closed and installed the weatherstrip on the body to fill the gap between the body and the door bottom weather strip where the dirt was getting in.
Problem gone! No more grit and dirt. Plus, I also filled a small gap in the rear door where the rear wheel well weather strip came short and no more road dirt gets in there either.
I will post a picture if somebody will give me some help. When I click on "insert image", I just get an "[IMG][/IMG]". Don't know where to go from there.Modified by Superdave54 at 8:33 AM 3/23/2008
Modified by Superdave54 at 8:37 AM 3/23/2008
How to post a picture::::How do I add pictures to a post?
To add pictures to a post on NICO, you need to first have an external (outside) host. Many members and staff use Iserve and you can signup there and for a nominal fee, have the ability to not only host and store pictures, but also a full assortment of photo-editing tools and the images aren't deleted after your membership expieres! Other free options include hosts such as photobucket, myspace or facebook.Once you've loaded up your picture, right click on it and you'll see 'properties.' Click on that and you'll see 'Address: (URL).' Highlight that web address, right click, and hit 'copy.'
Now go into your post and type in " [img] " with no quotation marks. After that, right click and hit 'paste.' Now after the address type in " [/img] " with no quotation marks. The [img] tage starts the image command and the backslash "/" ends the command.
It should now read [ img ]
http://your picture here. jpg [ /img ] but without the spaces (which are there just for informational purposes.)
Now hit the done button and your image should show up! Congrats! If you have problems and your image doesn't show, make sure you copied the address correctly and the image tags are in place with no spaces. After that, if your still having problems, contact a moderator.
Happy Posting!
