SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Sun Nov 06, 2005 10:48 am
^^love that picture too! Yes!!
17x8 +35 front clears coilovers with 215/45-17
Use this size front and rear to give you a neutral easy fitting package that you can rotate front to rear for maximum tire life.
or do 215/45-17 front and 245/40-17 rear
or do 17x9 +15 rear with either 245/40-17 or 255/40-17 but be aware the wider the tire and, considering your camber setting and ride height, you'll need to take a hard look at rolling very slightly. Easy job if you've ever done it.
With my 17x8 +35 FNO1's I did 215/45-17 front / rearI tested everything from 215 to 225/45 to 245/40 to 255/40 to some ill 275/35 drag slicks. it can all fit. What compromises you make to get it to fit is up to you really.
Good luck...
