FNO1r-c offset?
s14junkie
i was lookin on 5zigen website and they have 17X10 in fno1r-c the offset they have are +12, +25, and +35
what wud be the proper offset in the rear for the s14.... +12, +25 or + 35? and can the front use +15 offset when using 17X9 rims wud this clear the suspension, and the suspension mod i have are AGX with sportline springs.
thanx for ur help
BuudWeizErr
You afraid of a little work to make them fit? You afraid of a little camber?
If yes to those questions, stick with a conservative offset. +35 rear, +25 front, maybe some small spacers to push them out a little bit.
If you say no. +12 rear, +15 front with a 5mm spacer up front.
You may need a combination of the below:rolled fenderspulled fenderscamber
Depending on ride height and dampening setting, you will need to bang out the lips in the front fenderwell and relocate the wiring harnesses (30 minute job).
barrigas14
+12 in the rear +15 up front...be ready to roll the fender and have some skinny tires...maybe stretched?
BuudWeizErr
barrigas14 wrote:+12 in the rear +15 up front...be ready to roll the fender and have some skinny tires...maybe stretched?
yeah, forgot to say that. stretched tires is almost requisite if you run low offset. Think ~225/235 for 9/10 inch wheels. Unless he keeps the stock 4x4 look.
Exar-Kun
Car: 2005 350Z
why..oh why are you running 9" or 10" wide wheels?!?!?!?
...sigh. search around, I tire of repeating myself about the wide wheel thing...im closing this, for lack of searching, not reading the stickies..and general annoyance tonight at the public.-chet
