bcar240 wrote:anyone with an S13 chassis and looking at these wheels at least give this some thought, it REALLY needs a fender pull to look right, if I would have known they would have stuck out THIS much I would have gone with a narrower wheel.
Um, you just answered your own question........
Anyway, I'm running 225/40 on a 18x9 in rear - roll, yes otherwise you rub, unless you have mad high suspension. The only pulling really needed to be done can be had from side effects of rolling (i.e. rolling it will pull the fender slightly).
If you increase camber, you don't have to pull as much. When i went from -1 degree to -2 degrees, the wheel got tucked in about another .5" or so.
The fronts are relatively the same - I can't say tho bcs I have wide fenders in front.
