Different sizes of injectors cost different prices. Alot of times you will see bigger injectors cheaper than smaller ones. Summit is a prime example. I would go through Summit to get injectors since they seem to be the best price and will work with you on it and the price. Boost levels depend on the fuel supply. Thats really kind of a vague question you asked.QUICKFLOW240 wrote:well how much could I get a set of injectors capable of handling the max boost on a stock bottom end? and what would be that max boost?
8:1 FMU with just an FMU and stock injectors for 5 psi is running a little on the lean side but shouldnt do amy damage unless you are constantly at high rpm. I would recomend upgrading the fuel pump so it would at least be consistant. If you are wanting good condition low mileage stock replacement injectors, i have several. $20 each.Turbo_Nismo_EC wrote:Now here is my question...sort of on the same subject. Even though I have decided to sell my truck, I am going to install the turbo before I sell it. Now, I WAS going to use the JWT set-up, but I think that just to get it on the truck, I was thinking of using an FMU. Now, my fuel injectors have 153,000 miles on them and I am kind of worried about raising the fuel pressure and having one of them seize because of old age. Are there any replacement injectors that I can purchase to run with my stock ECU? I am only going to run 5 psi with this set-up and am planning on running an 8:1 FMU(the n-sport is 7:1 so this should be good). I just don't want to blow the motor because of an injector. I did a search and found about the 370cc ones, but those would cause my truck to run rich, and I am looking at getting the stock 270(??)cc ones. The dealership wants 400 bucks them, do you know of any aftermarket ones?
Ok that was a little much and I probably should have created a new thread..sorry....please bear with me
Thanks
Turbo_Nismo_EC wrote:Thanks for the replies guys!!
I am interested in the injectors you have for sale though. Could you give me a little more info on them like how you came about them and how low mileage are they?(uuh that sounds bad, but you get the idea)
Thanks again for the replies.
Turbo_Nismo_EC wrote:By the way...do all FMU set-ups run really injector high duty cycles like C-Kwik is talking about? Even if the injectors are new, won't that cause an injector failure running that high of a duty-cycle? Man, I am nervous running an FMU. On top of really high fuel pressures, now I get to worry about high injector duty cycles. This is exactly why I only want to run only 5 psi.
Movingviolation240 wrote:but still, with an FMU your pushing almost 100psi of rail pressure! Talk about a rig. You can expect all sorts of prolbems with injectors stalling out, and fuel leaks.
IMHO an FMU is a total waste of time, I've seen way too many KAT's be rebuilt because sombody was too cheep to shell out $75 for a set of SR injectors on Ebay and thought they'd do somthing easier.
If you havn't noticed I have a deep routed hatered towards those horrible devices. Please stay away.
PaulOrlando, FL
