Blown240sx wrote:
Doesnt change the fact they sound like some items you might see on a As Seen On Tv advertisement. The Turbo Encabulator!!!
Want the boost to hold off buy an electronic boost controller. Thats what the gain settings are for. Want to tune your fuel properly get Nistune or something thats safer than pushing the fuel pressure to gods country.
People do ghetto setups then wonder why their s*** breaks.
I'm gonna go easy on you because you're not a frequent KAT flyer and are obviously the type of person that judges others based on the amount of money spent and the bling attached to the name of the object. I shop at Ross and Wal-Mart and browse junkyards looking for deals. Maybe you can call me ghetto WD, since I am not rich. I fabricate my own manifolds, piping and as much other stuff as I can. I do this because I don't have a budget that allows me to do anything else. Does this mean I'm not extremely well versed in forced induction? No...
For those of us on a budget the FMU is an excellent way to supply the fuel required for on boost conditions. Are there better options? Duh...no one is arguing that. That doesn't change the fact that the FMU works and works well. Arguing that it isn't safe is not only dumb, it's wrong.
Notice you'll never hear (read) me say to run more then 8 psi without retarding your base timing or using another means to ward off knock. If I want to crank the boost up and use the FMU, then you'd have to assume that I'm not just doing so all willy nilly. I have the MSD knock meter, I have wide band O2 and I have a fuel pressure gauge inside the cabin. I will also not go over the max line pressure. I'm not telling anyone else to do do this...but I might.
The FMU is definitely not the cause of peoples failures. Bad uninformed choices and knock-off parts purchased on eBay have nothing to do with the FMU. The two can't be related. If anything, using the FMU is the only correct part of most budget setups. It's FAR better then the SAFC and other piggy back controllers. I could explain why but I doubt it would matter.
We have members right here on Nico that have been running the FMU for years with NO problems.
You may not mean to, but you're slandering like 50% of my forum. So go ahead and stop
WD
