FMU question
ftrs13
Car: KATs
Im putting it in today, and I believe that the center line is the inlet and the line coming out the side is the outlet, I just wanted to clarify this with someone
ThanksSteve
AceInhole
yes. just look at the stock FPR. both work in a similar fashion.
j-z
Car: 95 240sx
what fmu are you using?
ftrs13
Car: KATs
vortechI actually found out that it was exactly the opposite, for anyone looking at this with the same question
http://www.vortechsupercharger...m.pdf
should it matter though???it seems like it would preform the same function either way
AceInhole
oops.... i was right about it working like the pressure regulator tho.
tapdeznutz
is using the fmu the same as using a fpr. or can i use both or just one. please advice
