fmu for ka24det
tony/ka24de
what would be the best ratio fmu for the ka24det? I was thinking a 6:1. And because of the factorys 1:1fpr that would make the ratio 7:1 for every pound of boost(I think) Does anyone know if the sr20det fuel pressure regulator is rising rate?(_:1 or is it a 1:1)
C-Kwik
The NSport Kit uses a 7:1 and the XS Kit uses a 8:1. An SR uses a 1:1 regulator. FMU's are typically used in place of larger injectors. You won't find them as an OEM part.
cdigity
i've got the vortech s.f.m.u.works great! once its tuned right.still have stock injectors, soon to be 370ccrunning 6-7 p.s.i.
