S13Ka24e »
https://forums.nicoclub.com/s13ka24e-u2588.html
Tue Jan 28, 2003 6:18 pm
Sorry I wasn't clear on that. I mean to ask if my calcuation for this was right
the square root of 85/35 = 1.55 (35psi is the stock pressure?)
1.55 times 270 = 420cc
I just mean to ask if you rasie the fuel pressure (35psi) on the stock 270cc injectors to 85psi will it make the 270cc injectors flow at a rate of 420cc. I just did the 420cc calcuation because I thought a FMU was only good up to 250hp (or so) and would use one if I could could run up to 320hp.
I realize that I would only be able to run 7psi of boost, but hopefully I will have a custom intake manifold plus a port and polish, so I think that even at 7 psi I could be running close to 300hp at the fly.
But I found RC's website and found the equations and made sure I recalled them correctly. So I will use a 8:1 FMU from Vortech for my fuel. The 8:1 should make 91psi of fuel in the rail. I think that the 8:1 will be ok since the nsprort runs a 7:1.
Of couse if i decide to go for more boost I will have to go standalone or JWT. But for now I should be find with the FMU and for only $140 it not an expensive part if I change my mind.
