jrd450r »
https://forums.nicoclub.com/jrd450r-u48236.html
Thu Mar 10, 2011 6:26 pm
I am trying to figure out a way to make a drain for my holset hx35 to my block. I was originally using the stock rb drain cut and welded and then some heater hose to connect it to the fitting in the block, but this was not sufficient and was not draining fast enough. I just purchased a bunch of AN -12 fittings and hose to try and put together some combination. I made a holset drain to AN fitting for the turbo side and bought a 3/4npt to -12 for the block. No matter if I use 45 deg or straight AN fittings the cross member/motor mount is in the way.
What are you guys using for a drain? This is killing me that I can't figure out a way to do this. Thanks for your help!
