FMIC vacuum lines..
seanman
Car: 1989 Nissan 240sx
hey guys so my swap is almost complete, but i have no idea of what to do with all the vacuum lines now that im putting on the fmic.
duffman1278
Car: 89 240sx Hatch, the wildcats!
What do you mean? There's no difference really than a SMIC. In fact, it should be easier with a FMIC. Search it man, someone asked this yesterday and probably like 3 times this week
RPS13 DRIFTER
Car: S13 Hatch SR'D
one by the throttle body on the cold pipe for the idle air and one for your wastegate on your hot pipe everything else is on your throttle body
duffman1278
There shouldn't be any connected to the cold pipe. Assuming your BOV is on the hotpipe
RPS13 DRIFTER
Car: S13 Hatch SR'D
what do you mean?im talking about the big one for your idle air sensor on the intake manifold
duffman1278
OoOo that one. That one should be obvious lol I was only talking about the main 3 smaller ones
seanman
ok so those three coming off the intake: two of those still plug into that plastic black resevoir looking thing right? Also my rack and pinion is shot so i was gunna not run PS until its replaced, is there any way to plug the PS pump w/o removing the belt from the engine?
seanman
bump
duffman1278
Why can't you just stick bolt in the return and intake of the rack and pinion to block off the oil. Than just take off the PS pump.
seanman
the intake and return lines keep cross threading and popping out whenever i try to screw them into the rack
duffman1278
I had this EXACT problem. I had to take my rack and pinion off and than retap the threads. Might as well replace your rack and pinion, if its leaking, or old.
Rosco
Car: 91' SR'ed Hatch
Here is your answer to the original question:
Courtesy of heavy throttle:The vacuum lines are simple: 3 lines start at the throttle body. The bottom one goes to the canister, block it off unless you are using the canister. The larger one on top runs to the bypass valve (BOV), there should be no tee's or branches - go directly to the BOV. The smaller top line splits to the fuel pressure regulator, and runs across the front of the engine to your boost gauge and/or the boost pressure port on your boost controller.
The wastegate gets its signal from the nipple on the intercooler piping. The Apexi boost controller stepping motors go in between the IC piping and the wastegate actuator.
seanman
Rosco wrote:The Apexi boost controller stepping motors go in between the IC piping and the wastegate actuator.
is that what the little steel looking cylinder thing is with the one vacuum line coming off that splits into a t?
seanman
i just noticed/remembered theres an attachment point on the elbow just before FMIC, and im wondering what its for. and does that have anything to do with the large attachment point on the underside of the air filter? i still dont know what that vacuum line coming off the cylinder thing is..
seanman
bump
seanman
seanman wrote:i just noticed/remembered theres an attachment point on the elbow just before FMIC, and im wondering what its for. and does that have anything to do with the large attachment point on the underside of the air filter? i still dont know what that vacuum line coming off the cylinder thing is..
anyone?
ajolliff
So what if you dont have a vaccum nipple on the hot pipe for you wastegate? What can you hook the wastegate up to?
seanman
no i have the nipple, im using the stock hot pipe it the clip came with.
