FMIC rubbing
dillardkid121
Car: 1993 240sx w/ S13 Redtop
Is it a big problem if the bottom of my intercooler rubs a little? It occasionally rubs and some of the fins are bent on the bottom.
ZootedS13
Car: 1990 240sx se
i would try to fix it. it could eventually wear away and cause a boost leak.
dillardkid121
I'm pretty sure its because its crooked somehow but I dont know how to fix it
DanThaMan
Car: 1993 240sx
We can't help you without seeing the problem...post some pictures brah
dillardkid121
ok i will in the morning when its light out
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
get a PBM high mount intercooler if you are afraid. Also angle your car when pulling in and out of places also keep 2x4's in the car just in case. I personally wouldn't of asked this question and just went with the obvious "yes, it is bad". Typically anything scraping the ground repeatedly is not a good thing. :inoutgay:
dillardkid121
I didn't think it was that big of a problem at first.
Then i got under to look at the bottom
How big of a problem is this? Do I need to change it soon or can I wait to fix other things? Sorry about all the stupid questions im new to this stuff.
Hoffman5982
Car: '95 sr20det 240sx
Dude how did you manage to mount it that crooked? Yea Id fix that now. Better to do it before you have problems, that should be common sense
dillardkid121
I didnt mount it the guy i bought it from did. Got it for a steal and the car is super clean except for a few minor things.
dillardkid121
do i have to take off the front bumper to fix the problem or can i just fix it without taking it off.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
It's easier with the bumper removed, but you can do it from underneath the car... I'm 99% sure that the guy just rushed it together. If you loosen your hose clamps, and the bolt holding your intercooler, you should be able to get everything straight.. Once done, retighten everything back down.
ZootedS13
Car: 1990 240sx se
i think its time for a new core if thats a hole i see in that pic. and second of all, why dont you cut the hell out of that front bumper? it definately needs it.
p.s. i spy jamie thomas circa's i think.
dillardkid121
what do you mean cut the front bumper? No they are AL50 with crappy laces they are way more comfterable than my 205 volcs
OM3GA
I have Denim 205 Vulcs. My foot hurts bad but i still rock them.
Get a new intercooler core and mount it a lot better. The ISIS core is not a bad deal at all.
ZootedS13
Car: 1990 240sx se
cut the front bumper so it sits flush up against the intercooler.
FusionR300zx
Car: 1993 300zx/1997 240sx
godspeed IC's are good fitting too.
just put something between there so it absorbs impact/rubbing.
i did that for some spots of the IC piping.
OM3GA
FusionR300zx wrote:godspeed IC's are good fitting too.
I agree on the godspeed, my friend with a CA18 has one and it fits way better than i expected it to.
dillardkid121
ZootedS13 wrote:cut the front bumper so it sits flush up against the intercooler.
how should i cut it?
