charlotte240 »
https://forums.nicoclub.com/charlotte240-u912.html
Wed Sep 10, 2003 8:14 am
I wouldn't think that hooking up the wastegate to the BOV line would be the best solution. It would probably work, but the BOV line comes from behind the throttle plate and therefore get's alot of vaccume in between shifts. I would plumb a nipple on the hot line if I were you because that's stock and therefore "tried and true." On another thought, plumbing the nipple on the cold pipe would enable you to run a slightly higher boost level, because it wouldn't cut boost until there is 7psi after the intercooler as opposed to 7psi before the intercooler. I'm sure you already know about pressure drop and that stuff so I don't need to go into that.
