elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Fri Jul 25, 2003 6:43 am
Nick,I promise you wont have any trouble...... I thought about doing a write up, but once I got in it was soo easy no one could mess this up......
Anyway, heres how you do it.....
1. Take out the old antenna mast (if you can get it partially out, but the belt isnt broken, cut it), and take off the chrome do-whicky that the screw on thing threads into......2. Take out the right hand side (passenger) liner out......3. Unplug- the 3 connectors going to the antenna motor assy.... Theres a big one that goes into a silver box, a little one, and a black round one.... that one you have to pull on pretty hard......4. Unplug the drain hose..... Dont unplug it from the motor assy, but rather from that junction.......5. There are 2 bolts holding it in place.... Loosen those, and there is a bolt holding 2 ground wires, undo that also......6. The motor should slide right out.....7. Get a really tiny socket (dont remember the size off hand), and unscew it...... 8. Take off the black part..... The gasket is probably really sticky, so it will take a little to get loose.... Then you will have to maniplulate it with the hose to get it off...... I didnt even try to take the hose off...... There is a white, plastic looking disc in there, that is free so you can take that out to make removal easier......9. Dig around with a probe of somesort to get ALL (and I mean ALL, or you will have to repeast everything) of the old belt.... Mine was in like 4 chunks...... There is a metal looking gasket thing in there, that can be lifted out to reveal more belt....10. Lubricate everything really good, and then re-assemble and replace in the order you took it out.......11. When you are ready to put the mast in, have someone get in the car, and turn on the radio...... When the motor stops, put the mast in (fully extended) with the teeth facing toward the front of the car....... It may take a few tries, but once the motor catches it, it should go right down, and then just button it up and your done!!!
It may sound a little confusing, but I did all this in about 45mins......
