Dmnitsadean wrote: I really dunt know abouts perforamnce clutches and flywheels thanx....DeAn
If this is a picture of your engine... it looks like you have a completely Stock KA24E with the heat sheild on the exhaust header removed. Unless your stock clutch is worn out, your money would probably be better spent on a cold air intake and a Cat-back if you don't already have one. The clutch is only nescesary if yours is worn out or you have significantly more power than stock. The flywheel will make about as much difference as the CAI and Cat-back, but will require the engine to be pulled out to install it.
Also consider wrapping your exhaust header in some heat sheilding tape so it doesn't heat up the engine bay unnescesarily.
My build up plan for my daily-driver '89 240sx (se power convenience) looks something like this:
1 Fix what's wrong when I bought it. (Tires & Brakes)2 Remove easy to remove unnescesary weight (rusted-out jack & spare tire)3 Cold-Air Intake and Cat Back4 Replace Ashtray with Voltmeter (gone through 2 alternators and a Battery in 3.5 months... I think it's because the passenger side power door switch sticks)5 Replace motor mounts6 Port & polish Head, Street performance cam, Performance Exhaust header & Cat7 Lightened Flywheel and Clutch
I am doing #4 today.
Notice that things that require taking the engine apart or out of the car are at the end of the list.
Modified by Nanaimo at 11:53 AM 7/10/2005
