nocwage wrote:So why did you ditch the OS Giken for this?
i didnt 'ditch' the giken
this engine is stock block, stock head except HKS 256/8.5 cams a tomei 1.5mm MHG and ARP head studs
this engine isnt going to be pushing enough torque to warrent a twin plate, i didnt want to put it on at all, except i got antsy waiting for the new JUN (i traded a jun for teh giken)
the giken will go on the next CA18 build (the next engine i build)
built ca18 shopping list price item 110 bore block 83.5 200 prep block 572 cp 83.5 pistons+rings 784 pauter rods (maybe) 100 arp main studs 80 balance rotating assembly 300 tomei metal head gasket 150 high perf oil pump 130 new water pump 200 head prep 150 valve job 225 tomei valve springs 400 cam regrinds 250 adjustable cam gears 100 arp head studs120 power enterprise timing belt300 lightweight pulley set30 add tooth wheel to crank pulley200 magnesium valve covers50 bearings300 injectors150 FPR75 walbro fuel pump
4976 total
plumbing800 custom plenum with ITBs1000 fullrace tompount manifold1000 ballbearing t3/t04e type turbo100 BOV
2900 totals
this will be long after i have moved, and settled in teh new house and job
then it will go into my s13, that and probably convert the US body to RHD, and it will be 'done' engine-wise
then once the s13 is no longer a project, the ae86 will become the project/testbed and i get to drop any and every engine into it for fun .... like teh CA18 thats in my s13 now.... and the KA24E that came with the US body... and the 7MGE from the cressida, when i drop a 7MGTE in that... and the ca20det project, that will go in the AE86 too
so yeah... but also that the 9 bolts that hold the pres plate on the flywheel (on teh giken) are mostly stripped and gross... as they are really torx bolts... and for some reason i thought they were normal allen head bolts... so im waiting for a new set of bolts on that too
edit>
and i forgot who, but someone was working on using SR flywheels, and ive only seen tomei flywheels in teh 6 bolt (ca20) variety... and personally, ive never seen a toda flywheel, just the clutch package... unless i listed it in that otehr thread. i think that was just the clutch package
