Postby
yellow_jacket »
https://forums.nicoclub.com/yellow-jacket-u4236.htmlMon Sep 20, 2004 5:27 am
Excedy makes a twin disc setup that comes with it's own flywheel. I talked with the manufacturer about it for about a half hour this weekend. It is supposed to last a long time and be streetable(moreso than a single disc) It is about $1300
Postby
tomi240sx »
https://forums.nicoclub.com/tomi240sx-u11909.htmlMon Sep 20, 2004 6:24 am
yo goofy, how much for the flywheel? will it fit a rb25det clutch? I read on rb25det.oqg that it's suppose to be the same as n/a 300zx but after talking to jon, I'm not so sure. If it fit, how much to 70817?
tomi I am perty sure the bolt pattern on the crank is different on the 300na and the rb25 I can check in the am and make sure ...i bought a 300na flywheel as a back up and it fit the clutch but not the crank...
the Z32 flywheel (all of them) are different they are i belive a 8 hole bolt pattern and i belive rb20 is a 6 hole120 tooth ring gearBut it accepts a Z32 NA clutch
Postby
tomi240sx »
https://forums.nicoclub.com/tomi240sx-u11909.htmlWed Sep 22, 2004 6:59 am
goofynick: can you email me with your name number and address?
Boostsfed: sorry it didn't come out the way I wanted. what I meant was that I'm just looking for a stock flywheel unless it's expensive then I will go aftermarket. thanks for your info, once again sorry.
