Flywheel
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
I'm looking for a flywheel for my SR20DE... Since a Maxima clutch will work, I assume the flywheel is the right size, so would the flywheel from a VG30DE work?
I know a VG30E won't, since those are 6 bolt, but the DE is an 8 bolt.
I'm not looking to spend $400 on a lightweight one, I don't need that. I'm just looking for a cheap, stock-ish flywheel and clutch.
A VG30DE flywheel and clutch looks like a good match on the SR20, if it works.
Thanks
Nismo_Freak
Car: 89 Nissan 240SX
You can use a DET flywheel.
I have a spare one you can have for $60 shipped with the DET clutch. It'd be an upgrade for you.
Email me - [email protected]
Seishuku
So a VG30DET flywheel bolts on? Will that work, it's 10MM larger than the stock flywheel (won't hit the bellhousing or anything?).
Seishuku
Edit: nevermind that
Modified by Seishuku at 10:38 AM 10/27/2005
