Flywheel runout question
gthammers
Car: 1991 coupe, 1994 coupe
I had my flywheel resurfaced as part of my engine rebuild. In putting everything back together and checking all specs the flywheel has too much runout axially. FSM says >.006", I'm seeing .010" - .011".
I don't want to take it back to the same dumb***, but everyone else is a long ways away. My guess is he used the back side of the flywheel as a reference surface, instead of the crank mating face.
What will happen if I run like this?
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
whoa Greg, i wish i knew exactly what would happen.
However, since you already checked it yourself i can tell you're concerned, as you should be.
did you get the correct step machined into the flywheel? if so i would measure the runout on that surface and decide from there.
otherwise a part that is out of spec will worry you every day and every shift of your life. Its possible nothing will happen, but i know you'd rather have the piece of mind.
you should make sure it has the correct step machined on it (is it .008? i forget, but any reputable machine shop should have checked their books), test that run out, and then take it back and tell them your problem.
something that is two-fold out of spec like that would worry me about a slipping clutch a few thousand miles down the road.
and if you really cant find someone near you, its possible you might wanna think about buying a lightweight fly... although i know i never had the cash for that, and maybe you dont either
