Ok, thats what i like to hear. Any others?bone_stock_240 wrote:When I got my flywheel resurfaced, it was done flat. This was for my KA
I have the Centerforce DF for a DOHC KA24DE. Thanks for the help though.r34 gtr wrote:i believe it depends on the clutch you get. mine was done flat but im using a metal clutch.
I did. Ill try again.r34 gtr wrote:ask centerforce! if anyone can tell you what way to need to resurface the flywheel itll be them.
I just got the clutch this morning and it doesnt say anything about putting a step in or what size. What other Nissans do you know that have this type of setup? How about your dohc KA's setup? i keep hearing things from both sides of the story.float_6969 wrote:I know that my SPEC didn't include anything that said it was supposed to be stepped, and since I had it done flat, the friction point is WAY up at the top of the pedal. It kinda sucks.
Almost all Nissan flywheels are stepped, so I would think it would need stepped.
I see!float_6969 wrote:poor side demo of flywheel;____-----___----_____The contact area is raised above the pressure plate "bolt down" area
What should the step be if I buy the Enjuku Stage3 clutch for the ca18det?boost_boy wrote:Having it stepped is the way to go!
Dee
They will know what to do with your flywheel!page02wrx wrote:Does anybody know the answer to that? I'm emailing Enjuku I hope they speak english
Im still trying to find the actual spec. If anyone gets it do post it up!float_6969 wrote:Don't you think I would have tried that? I'm not from the south, remember?
Even if you adjust it out to the max, it's still not right. The flywheel needs stepped, end of story.
If you do get a distance, please let us know what it is so I can sticky it.
So basically, what does the stock flywheel get stepped to?Jason @ Enjuku wrote:
Broc, Its just the preferred clutch for the CA. The flywheel should be stepped just like oem would be. The pedal feel vs 4 and 6 puck isnt that big of a difference. Pedal feel is the same. If you have any other questions feel free to email us anytime. Thanks Jason
It just the way the flywheel is cut to accomodate the disc. If the factory intended for the clutch to ride on a stepped flywheel, then the person machining the flywheel will know to step it (Having the friction surface a step higher than the rest of the flywheel). Or you can just have it flattened out and go with it that way. It sounds about right, but I could be wrong.page02wrx wrote:So I talked to Jason, from Enjuku, via Email. I asked him about stepping the clutch on their stage3 clutch I bought, and the difference between 4 and 6 puck.... and this was his response
same with mine.. got it flat and cheages the feel of the petel..my nismo was stepedfloat_6969 wrote:I know that my SPEC didn't include anything that said it was supposed to be stepped, and since I had it done flat, the friction point is WAY up at the top of the pedal. It kinda sucks.
