Flywheel resufacing question...
encasemyheart
I'm about to install the Spec stage 3 on my 240sx. My question is do I have to resurface the flywheel? I have heard as long as it is not cracking or anything then just clean it with brake parts cleaner, is this true? Every clutch I have installed before has gone with a lightweight flywheel, so this was never an issue.
The single part I hate most about clutch installs is removing the flywheel, so if I will have to remove it for resurfacing I'll just pay the $130 to have a shop install it.
Anyone know? Help ASAP would be appreciated.
NISTECH
if its not glazed ,have hot spots, or cracked then no you dont have to spin it. just hit it with a lite sand paper spray it off and run with it. if any of the mentioned conditions exist i would recommend turning it.
trpower7
I always have the flywheel resurfaced. It's only about $25 at my machine shop and worth it every time. A maligned, glazed, or cracked flywheel can have some bad repercussions, especially on that new clutch of yours.
SHIFT_Lock
Car: kouki s14
yup i agree with everyone. also have a little step machined into it to give a little extra bite.
Scott McLellan
Plan on buying new flywheel to crank bolts. I didn't and busted a bolt when I was torquing them back in. Got to 20 lb. ft. and one of them twisted in half. They are 6 dollars a bolt and you'll need 6. I had to order mine from a dealer. If you don't buy them plan on buying drill bits and screw extractors and maybe some medication for the huge headaches that go along with breaking parts.
slip
Car: making things go faster
i allways resurface the fly wheel and you should to i havnt had to replace my clutch yet but will upgrade it soon,but have replaced many on other cars at my shop.never had a flywheel bolt break i wonder if the bolts on the nissan are torqe to yeld if so that would explain it if any one knows please post it,or someone could have been lazy last time they did the clutch and ran them down with an impact.but replacing the bolts either way is not a bad idea...............................................thanks
NISTECH
slip i dont know a tech out there that doesnt run them down with out an impact gun. if air is available thats the way we all run them down.
trpower7
It's usually only GM cars that have the torque to yield bolts, most Japanese and German cars ALWAYS specify a torque value. I usually run it in with a gun then check it with a torque wrench.
574-240sx
Car: Nissans, Toyotas, Subaru
Yeah i used an impact only to put them on. I didn't take the extra time to torque them down and 2 days after installing my flywheel, bolts loosened up. I guess that will teach me to never check torque specs. Nick
encasemyheart
Yeah when I first looked at the flywheel, it was very smooth and slick. Well it was also cracking slightly (surface cracks) and there were obvious hotspots. I thought it was supposed to be slick though. I had it machined, 15 minutes and $45 later I had a rough surface flywheel that looked 100x better. My machinist told me that the surface was also bowed so it would have caused me problems down the line.
Thanks for the advice guys.
