Flywheel replace?
jlee29
Car: S13/15 6.0 Chevy V8 :-P
Mazda Protege Kicker L7 15" (Beater)
I am getting a new clutch setup,(Because the previous clutch was to aggressve) the flywheel thats on the car is an aftermarket one with about 6k miles on it, seems to be in pretty good shape...
-Should i just replace the flywheel when i get the new clutch?
-Can you get a Flywheel Turned?
-Will the current Flywheel be fine with a new clutch?
Justin35ll
Car: s13 coupe sr20det
You can get flywheels resurfaced at a lot of automotive stores. I got mine done for 24$. The new clutch kit should work with the flywheel as long as they're the same sizes
