knightrider »
https://forums.nicoclub.com/knightrider-u3208.html
Sat Feb 21, 2004 4:15 pm
what ya can do, is take a couple of the presure plate bolts in the flywheel, and use a bar and pry against those 2 bolts to keep the flywheel from spinning while using a breaker bar for the bolts, easiest with 2 ppl. and what i did when i pulled my ca, put the presure plate bolts in, then lower the engine onto an old tire, catchin the bolt under the bead of the tire, then using the breaker bar.
