f s t caz »
https://forums.nicoclub.com/f-s-t-caz-u11665.html
Mon Jan 19, 2004 6:01 am
put one of the side transmission bolts back in to one of the side holes. now have a friend use a good size flat head screw driver and the bolt as a pry point and stick the flat head into the teeth of the flywheel and stop it from turning.
if you have a long enough breaker bar, you can put the 27mm on the crankshaft, and turn the flywheel enough so that the breaker bar presses against the tension rod bracket. That will do the job of holding the crankshaft in place if you don't have a friend there to hold it.
