Doogz »
https://forums.nicoclub.com/doogz-u5748.html
Fri Apr 18, 2003 4:31 am
Well, i saw this earlier and i wasn't going to answer b/c i wasn't really sure...but since it has sat here with no responses, i'll add something to it. I would think that a lightened CA18 flywheel would be better than the stock ca16. Although i'm not sure but if you switch to the CA18 flywheel would you have to change to a clutch and pressure plate for the CA18? If you would then i would stay with the 16 b/c that would be alot of things to buy just for a flywheel change. Or they could be exactly the same and you wouldn't have to change clutches, in that case i'd go CA18.
