Flywheel, Pressure Plate, Rear Main Retainer Torque? (Searched)
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
Can someone give me the torque specs for the flywheel, pressure plate, and rear main seal retainer? I completely forgot the specs and was referencing the KA24DE flywheel and pressure plate specs (110-125 ft/lbs and 66-69 ft/lbs via ALLDATA). I also have specs for the SR20DE for 96+ SE-Rs. i completely forgot the rear main retainer specs.
And could someone confirm if the flywheel is surfaced flat like a KA (meaning no step in)? What should I tell the machinist when I bring the flywheel in for resurfacing?
Flywheel Specs: 94-101 ft/lbsPressure Plate Specs: 22-33 ft/lbsRear Main Seal Retainer Specs:???
Flywheel Resurface Specs (if any) : ???
Modified by jdm_master_X at 3:06 AM 5/20/2006
Modified by jdm_master_X at 10:46 AM 5/22/2006
jdm_master_X
just finished doing more research. still need pressure plate and retainer bolt torque. any idea?
jdm_master_X
bump bump bump.
damn there were so many heat checks on my flywheel. i dont even know if its serviceable anymore. anyway, i still need the torque specs. any takers? thanks!!!
jdm_master_X
flywheel was done today. i noticed that the rear main seal was good when i pulled it out (well i damaged it so of course i need to change it now). i think that the leak is coming from the lower oil pan as well because the seal between the block and pan leaks when you depress the bottom portion of the pan.
noticed also that the valve cover was leaking a little bit onto the transmission's top. so i fixed that.
slave cylinder is shot. any ideas on how to bypass the damper box for cheap? i dont want to purchase the nismo line right away, but unless the mod is worth it, suggestions are open. and why is the nismo slave so expensive? is it really that big of a difference?
anyway, im still wondering about the pressure plate torque. anybody have it?
95silvia14
Car: 1995 240SX, 1993 s13 coupe
25-33 ftlbs
jdm_master_X
okay cool thanks man. and btw, welcome to NICO!
i did a lot more searching around on my car and yeah, my back hurts, so i wont finish till the morning. ill let you all know what i find.
95silvia14
just when you torque them torque them to 6ft first in sequince then to 12ftlbs and finaly 25 to 33 ft lbs if you need any thing else let me know and thanks for the welcome
jdm_master_X
omg bad news guys. while my friend and i were torquing the flywheel down to 94 ft/lbs, one of the bolts just broke off. so now i have the lower end of a bolt in the crank. is there anyway i could remove this? and does anybody have a spare SR20 flywheel bolt (or identical)? i will paypal money to whoever can name me a fair price.
what would happen if you bolt up the transmission like that, with one flywheel bolt broken but the rest torqued in sequence. i need my car back on the road so i can save my gas. my friend said it would be okay, but ive heard that it can create some sort of imbalance at mid/high rpm? someone confirm this for me, please! weaksauce.
jdm_master_X
bump bump bump?
does anybody suggest the right type of bolt extractor for the flywheel bolt?
i am still willing to paypal someone out there if you have the flywheel bolt that i need. im really desperate to get one. please!!
vutony
how many do u need...make offer at [email protected]
i have some off a kade...not sure if theyre the same or not
95silvia14
CURTETSY NISSAN SELLS THEM FOR LIKE 5.87 OR SOME CRAP LIKE THAT AS FOR A BOLT EXTRACTOR JUST GO TO SEARS AND TELL THEM YOUR PROBLEM THEY WILL GET YOU THE RIGTH TOOL
BEFORE YOU COMPLAIN IM AT WORK AND THERE IS NO WAY TO TAKE OFF CAP LOCK
jdm_master_X
finally got that bad boy in there. from now on, motor comes out too. haha.
thanks for the help man, i really appreciate it. did that dampener delete while i was down there.
oki_bum
Car: SR Powered 1990 240SX
so this is prolly a dumb question, but are those the right torque specs for the SR? I mean, you said that you broke on of the flywheel bolts....And did you ever figure out the rear main seal retainter torque?
jdm_master_X
well the FSM even says 94-101 ft/lbs. as far as the rear main seal, i opted to get a seal puller so i didnt have to unbolt the plate. to unbolt the plate u have to remove bolts within the crank case.
i just torqued them all to 85 and used loctite.
oki_bum
thanks, i spent the last 20 minutes trying to get that rear main seal cover off with no luck, so i guess i'll try it your way and buy a seal puller. And us said u used loctite? Thats some sort of adhesive? I did a search on google and thats what came up.
jdm_master_X
yes sir. always use loctite on flywheel bolts so u know they wont wiggle loose during harsh conditions. and always have a reliable torque wrench. make sure to tighten the bolts every other time (like if you start from the top, do the bolt at the bottom, and then right to left, and so on). and do it in steps (like if you plan to torque it to 94, do it in 3 increments of 30, and inch slowly to the final torque).
180fan
Car: 89 fastback
do em in a criss cross. Didn't have any problems with mine.
rear seal, you can pry out with a small flat head screw driver.
oki_bum
How did you guys torque the flywheel w/out it turing with the crank? Im doing this by myself...and just holding the flywheel is definitly not gonna do it.
180fan
Car: 89 fastback
impact wrench. if you don't have access to one, you can always pop a 27mm socket on your crank pulley bolt and use that to hold the crank steady.
oki_bum
thanks just finished an hour ago...was a pain in the arse to put the transmission back on.
jdm_master_X
its so much easier to pull the motor out than to pull the transmission by itself. again however, that experience comes with doing motor swaps all day long. haha.
