So.. I have been working to see what is available for flywheel options and any data I can come across while I try to select what I want to use.
If anyone has any more data let me know and I will add it to the list
Fidanza Aluminum 10.5lbs
XTD Chromolly 11lbs
Aasco Aluminum 11lbs 12.5 for turbo
rps Aluminum 12lbs
f1 Chromolly 12-14.8lbs
Jun Chromolly 15lbs (6.8kg)
Clutch Masters Aluminum ???
Spec ?? ???
If anyone has any good info on clutch kits I think that would be helpful also
I would love to get some info on the weight of the kits.. I have heard Exedy is the lightest by many pounds, but no data at all to back it up
thanks
Mark
