breadbox »
https://forums.nicoclub.com/breadbox-u49113.html
Fri Jul 30, 2010 6:50 am
^Good Call, Biggie, I usually forget about that.^
Things you need for a 5speed swap.
trans/crossmember/driveshaft
gussets(brackets from motor to trans)
Clutch master cylinder/pedal/hardline
flywheel/clutch/dustshield
and all the bolts pretty much too.
Brake pedal if you'd like
