Flywheel Bolts
John Dixon
Car: 300ZX-TT Z32
Anyone know the dimensions of the flywheel bolts and the thread diameter / pitch.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
No flywheel, just torque converter. Is that what you are asking?
Raxephon
Car: '04 RX8...for the moment...
maxnix wrote:No flywheel, just torque converter. Is that what you are asking?
He probably means the flexplate bolts.
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Flywheel is what the starter engages? I could probably check latter today.
Raxephon
Q45denver wrote:Flywheel is what the starter engages? I could probably check latter today.
Manual Transmission = FlywheelAutomatic Transmission = Flexplate
Both are engaged by the starter.Both bolt to the crankshaft with 8 bolts.Flywheel bolts are longer than flexplate bolts
Difference being that one is for a clutch & pressure plate while the other is strictly for mounting a torque converter.
Q45denver
1990 Infiniti Q45
I took some off a couple weeks ago. They were 14mm and about a half inch long. Can't check the pitch right now but probably the same as other 14mm on the car.
defrag010
IIRC, the actual thread part of the bolt is M12 x 1.25 or 1.5.. dont hold me to that though.
John Dixon
Car: 300ZX-TT Z32
Cheers guys, I have some 300ZX ones and didn't have the engine handy to check if they were the same thread or not. M12 x 1.25 seems about right.
