flywheel bolts
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
i was wanting to resurface the flywheel on the ca before i put on a new clutch. What do you guys think? do I need new flywheel bolts? Where would I get those?
Before I hear search, this is what I found...... on ca18det.org
Flywheel Bolts 12315-55M00 $2.18 is this usdm flywheel bolts for the pulsar nx? Front drive is the same? Is that a nissan part number?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Kouks wrote:i was wanting to resurface the flywheel on the ca before i put on a new clutch. What do you guys think? do I need new flywheel bolts? Where would I get those?
FWD bolts are too short. I was selling the right ones on here for a while, but only because I was forced to buy a box of 100 from the fastener store (read: special order only). In case it helps, you need M10x1.0x30mm with a metric grade of 10.9
Kouks
thanks C-rad, so these are JDM bolts only? ca18et bolts work? I doubt I would be able to find those bolts at any regular auto parts store.
Kouks
bumpety bump bump
c-rad
Kouks wrote:bumpety bump bump
??? Just find a fastener shop and get them. That's the only way.
Kouks
youre saying the cadet has its own set of flywheel bolts that doesnt have any crossover in america? that is retarded on Nissans part, but whatever. Ill look for those today.
float_6969
No crossover available. Sorry!
