They are an M10x1.0 bolt and would probably be close to the 20mm length available in the grade 10.9 and even grade 8 bolts at AutoZone. However, I think all of those AutoZone bolts come with a flanged head, and that might cause clearance issues between the bolts.Diggity240sx wrote:What is the exact size check Advance they probally have them....if you can tell me size and length....I can tell you for sure. You wont have to wait on shipping. I know Jegs carry similar stock as well. What is the thread pitch of the stock ones...You would need M14 for your tq range.
If he overtorqued one, he probably overtorqued them all. They may be stretched but appear to be OK. To be safe, I would replace all of them.Geno750 wrote:Are all 8 bolts bad?
I just followed the FSM, set the wrench to the Nm and it was about 94ft lbs which all bolts with exception to 3 did. 100 is probably too much.DuckyD wrote:
I too followed some write-up suggesting ~100lbs which is way too much. I snapped the head right off the bolt which isn't too fun.
Its 94-101ft lbs per the fsm.itsnever2fast wrote:torque spec is 104-112 lb/ft. some were overtightened. some were not. i am replaceing them all anyways to be safe
