Flywheel bolts and other interchangeable parts
robbbby
I need new flywheel bolts, will the KA bolts work?
Also are any of the intake gaskets on the SR same as KA/SER, either intake/head or collector?
How about the little circular gaskets that rest on the head that prevent oil from leaking into the plugs SR20DE ones work?
Getting carried away but one more thing, how about in the bellhousing the carrier piece that holds the throwout bearing, will a KA one work.
Thanks.
silva180sx1515
no the ka flywheel bolts will not work. for one, i think the ka only uses 6 bolts, while the sr uses 8. you can get the one from the ser sentras with the sr20de. i'm not sure about the carrier piece in the bellhousing. there are many parts that are interchangeable with the sr, search
slow s13
Car: cars, photo, music
I used all ka stuff on my SR bellhousing, works fine.
