Flywheel and clutch torque specs
Joe
What are the flywheel and Clutch torqued to on a RB25?
thanks
SHIFT_Lock
Car: kouki s14
flywheel bolts are 14.5 to 15.5 kgm's(108 ft lbs)
the clutch is not a huge deal on torque spec just make sure it's pretty tight and done in the correct patteren.
Joe
thanks shift lock!
Nameless EJ6
Car: What the **** do you think.
Kamin what clutch are you using? I need to get one soon.. not sure what to get though.
I'm kindof in the same boat with the auto engine..
Joe
I got a RPS clutch thats good to about 400ft lbs of torque.
http://www.turboclutch.com - RPS's site.
if RPS is good enough for F1 and the supra owners swear by them. im sure it will be fine in the rb.
Nameless EJ6
Thanks.. I just may go with them too.
