USAF_G35_Guy wrote:^ Good point.....could be the reason I'm having transmission problems at the moment. 20k miles give or take later after the install. OR it could be the fact that everywhere I read the 03 trannys SUCKS BALLZ! Either way, I'm sure my occasional roasting of the tires doesn't help either
I think it helps a little to remember the main reason the flywheel is there in the first place, to even out torque pulses. However it also has some features that have to do with balancing harmonics along the length of the shaft and in this case the shaft varies in length as the clutch is engaged and disengaged.
While not the case with our engines some are designed without a main bearing at the output of the final drive, relying on the equipment connected to it for support. For example a generator will sometimes carry the load normally associated with this bearing. The flywheel is still present in some cases where the generator is not the starter. If you change the weight in this case of the flywheel you just changed the loading on the bearing away from the ouput of the final drive. If the bearing is present sometimes the generator rotor will hang off of the end of the shaft unsupported by a bearing of its own. A change in weight now will often affect the bearing next to the final drive bearing more than that of the final drive bearing itself.
Sort of hard to explain, but maybe consider that the output bearing like the support of a teeter totter. One end of the teeter totter is where the next bearing is located, the other the input shaft bearing of the transmission. Changing the flywheel characteristics from design will affect everything else. Changing anything else such as aftermarket clutch assemblies, pistons, rods, damper/pulley, will affect everything else as well. Even oil temperatures will play into it.
In the case of large industrial equipment there are ways of tuning these changes. Where shafts bolt together (where bearings are also located) you will often find balance slugs used. Not only for adjusting shaft balance but for harmonics along the shaft. I find the procedure very fascinating to watch, some of the test equipment is simply unbelievable in scope and it takes a very well trained engineer to get it 'right'.
Perry
