mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Tue Jun 26, 2007 8:21 pm
Unless you're planning for some extra power, generally the stock clock would be more than enough. The flywheel is an excellent choice, it will make a huge difference.
IMPORTANT... before installing them into your car, take the flywheel and pressure plate to a good machine shop to have balanced. They're generally balanced from the factory but you want the pressure plate balanced with the flywheel so that both are correct. I've seen some nasty catastrophic failure when its not been done. Plus, it will make the whole setup smoother as well so that's always a benefit. I've been quoted between $50-$75 so its not all that expensive and definitely worth it.
Good luck with everything!
