Flushing Engine block, already out of the car
IronMonkey
Hey guys, I took my rb25 out of the car over a year ago, it's been sitting ever since. I started working on it, and realize there's a lot of corrosion and deposit left from the dried up coolant. What's the best way to flush it before putting it back in the car. Thanks
themadscientist
IronMonkey wrote:I took my rb25 out of the car over a year ago
Rebuild that. :poke:
IronMonkey
anybody? i was thinking about getting water hose thru thermostat housing (thermostat removed) and drain plug in block removed..... any additives to remove/break things up?
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
Machine shops hot tank for cheap?
I have been using a high pressure washer and carb cleaner on engines with great success. Try letting the carb cleaner soak in and then use a wire brush on it. Should work okay for blasting out the water passages too.
