They do make an a/c flush that's a very light oily substance. I used it once on my '97 truck. I had the system open to replace the evaporator than had a fairly large hole punched in it with a screwdriver. Someone got a little too aggressive trying to clean out the evaporator drain.
I poured it in to the different components and used compressed air to blow it out. I think it was something like this.
http://shop.advanceautoparts.com/p/inte ... 7CL3*15920
Typically, if you're not overly worried about debris in the system, you'd just do what Hitman mentioned... vacuum it down, replace the drier, and recharge.
