GQM45s »
https://forums.nicoclub.com/gqm45s-u193151.html
Tue Aug 14, 2012 8:37 am
So I found this on the RP site.
Max ATF is a synthetic, high-performance, automatic transmission fluid. Its low co-efficient of friction and high film strength help to dramatically reduce heat and wear. Additionally, Max ATF is more oxidation stable than other transmission fluids for longer fluid life.
Max ATF significantly reduces heat to extend the life of your transmission. Automatic transmissions generate a great deal of heat and depend upon the transmission fluid for cooling and protection. More than 90 percent of all automatic transmission failures are caused by overheating; a 20°F reduction in fluid temperature can double the life of the transmission (Source: Perma Industries, Inc.).
Max ATF is fully compatible and can be mixed with other automatic transmission fluids; however, for the best results drain or flush the current oil and then fill with Max ATF.
MAX ATF IS RECOMMENDED IN VEHICLES REQUIRING ANY OF THESE AUTOMATIC TRANSMISSION FLUIDS:
Allison C-4, TES-295 Mazda ATF-M III, ATF-MV
Audi G-052-162, G-052-990, G-055-025 Mercedes Benz 236.1, 236.2, 236.3, 236.5,
236.6, 236.7, 236.9, 236.10, 236.11
BMW 7045E, LA2634, LT71141
Chrysler ATF+, ATF+2, ATF+3, ATF+4 Mitsubishi SP-II, SP-III
Chrysler Mopar AS68RC Nissan 402, Matic-D, Matic-J, Matic-K
Ford FNR5, MERCON®, MERCON® V Shell 3403, LA2634
GM DEXRON®, DEXRON® II, DEXRON® IID,
DEXRON® IIE, DEXRON®-IIIF,
DEXRON® IIIG, DEXRON®-IIIH Subaru ATF, ATF-HP
Suzuki 3314, 3317
Texaco ETL-7045E, ETL-8072B, N402
Esso LT 71141 Toyota T-III, T-IV
Honda ATF-Z1 (except in CVT’s) Voith 55.6335.XX (G607)
Hyundai SP-II, SP-III Volvo Pass Car (4-6 Speed AT), 97340
(Construction Equipment), 97341
JWS 3309, JWS 3314, JWS 3317
Kia Red-1, SP-II, SP-III VW G-052-162, G-052-990, G-055-025
Idemitsu K17 ZF TE-ML, 03D, 04D, 05L, 09, 11B, 14A,
16L, 17C, TE-ML 14B
JASO 1-A
MAN 339F, 339 V1,339 V2, 339 Z1, 33
