Scott,
Thanks for your reply, I'm planning to replace the belt next year. I found out this weekend that my battery is 4 years old and replaced it as well alltogether with the terminals.
Where do I pour the stearing fluid ? Is this that small "can" on the passenger side on the strut tower, by the fuel filter and fuses ?
What did you put in there ? ATF ? As I remember Wes was saying in some of the posts ATF should be put in there. Wes am I confusing something ?
Scott, did you replace tha alternator just in case ? or it failed
Thanks
gr8scott72 wrote:Here's what I've done to mine in the last 6 months or so:
transmission flushNew plugsnew tireschecked padsflushed brake fluidflushed coolantchanged rear dif fluidswitched to mobile 1 oilnew alternatornew batterytiming belt replacedpower steering fluid replaced (and 2 leaks fixed)sway bar (tension bar) bushings replaced
