fluids
chiwon
Car: 2003 maxima
Hi everyone,I'm new to this site. I have a 2003 maxima GLE and am planning on changing the transmission and differential fluids. I was told I need about 5 qts of the Nissan Matic D transmission fluid. Anyone know what type of differential fluid I would need? Do I have to use Nissan's ($19/qt) or can I use something I can get at Pepboys? And how many qts would I need? Thanks for your help
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
No separate differential fluid since the car has a transaxle. Trans fluid serves both units.
When exchanging trans fluid, the BEST route to take is to be prepared with 10 or 15 quarts. Since drain-and-fill does not get all the fluid out of the system, you must change the ~5 quarts (I believe you're correct on that number) you're able to drain, then drive the car for a few days. Then drain another 5 quarts and fill with 5 more fresh. Then again, if you want. That way you get the most possible old fluid out of the system.Best way to be sure you're filling the correct amount is to measure what you drain. Then refill that amount and, if necessary according to the dipstick reading, top off from there.
Anything Dexron II compatible will work with the 4-speed auto, you don't have to get genuine Nissan fluid. MIGHT be Dexron 3 for the '02 and newer so check your manual to be sure...it'll confirm either way.
chiwon
Car: 2003 maxima
Thank you Minister of DOOM for your words of wisdom. Appreciate it!!!
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Just changed motor oil and tran fluid. Since I am on auto rampsI only get about 4 quarts of tran fluid out. I measure what I takeout so I dont overfill. I dont drop the tran pan, just let out thefluid with a drain plug.
Its overkill but I change mine every 6K as its only $9 for the WalMartDextron 3.
ABNRML4U
Car: Nissan B13
NutriaforBreakfast wrote:Just changed motor oil and tran fluid. Since I am on auto rampsI only get about 4 quarts of tran fluid out. I measure what I takeout so I dont overfill. I dont drop the tran pan, just let out thefluid with a drain plug.
That what she Said:
