CPS »
https://forums.nicoclub.com/cps-u98655.html
Sun Mar 22, 2009 5:35 pm
K&N's oil filter is somebody else's filter with a nut welded on and a K&N sticker. I'd go with a WIX or a Purolator Pure One. Less money and a better filter.
If you're gonna spend the money on Redline in the transmission and rearend, you might as well go all Redline. But I do have to tell you that unless you have a ton of miles, there is no reason to flush the power steering fluid. As for brakes, I would go with DOT 4 regardless of what brand you get.
BTW, the factory recommended manual transmission fluid is 75/85. We have had a customer complain of a notchy shift with 80/90 in it, so it's pretty sensitive to what you put in there. The factory fluid is synthetic as well, so it lasts a lot longer than you may be thinking.
On the rearend, you may want to check around and see what everybody else is running. My car (not a Nissan) recommends 75/90 in the rearend, but everybody on the planet runs 75/140 in them. If you do a lot of high speed driving or extreme stress, the extra viscosity when the rearend gets hot helps keep things lubricated. Might be worth looking in to.
