Fluid changes?
cousteau77
What quantities of fluid would one need to replace the Brake, Power Steering, and Differential on a 93 Q?
Any help would be appreciated?:help
Thanks, Jacques.
Q451990
I'd go ahead and get two 32oz containers of brake fluid (I use valvoline syntec) for a really good flush. With the differential, I' think three bottles should do it. The problem with refilling the differential using the bottles, is you have to almost crush them to get the bottle aligned correctly with the fill hole. P/S, 1-2 quarts? I turkey baster mine at every oil change instead of a complete flush.
Your owner's manual should list capacities. If your owner's manual is missing, use the specs. from the 95 or 96Q on http://www.infiniti-techinfo.com.
Heath
