The test strips that I am using are made by Phoenix Systems. Here they are:
https://www.amazon.com/gp/product/B0753 ... UTF8&psc=1
They are still being marketed.
Test strips are sealed, individually, in a foil wrapper. I’m not concerned about contamination, they are exceedingly well packaged.
These strips do not measure the moisture content in the brake fluid directly. Rather, they measure the copper ion content of the brake fluid. So, they are not measuring the cause but rather the effect.
There are brake fluid test devices that are affordable and that measure the moisture content of the fluid. I was going to go with one, but my research made me confident that the strips will give an early warning of any damage to the system, so that’s the way that I went.
Yes, in the Seattle area you have to be more careful of your fluid that I do. We get a lot of humidity in Minnesota, but don’t have the overall concerns with moisture that you do. I have the Infiniti in Minnesota. We are snowbirds and live in Arizona in the winter. I have a 2002 e39 in Arizona (a different one than the one that I used to have in Minnesota that used Dextron in the General Motors designed transmission, this one has a ZF designed transmission with synthetic fluid). I bought this car used, and presume that it never had brake fluid changed. It now has about 110K miles on it. I have been using these test strips to monitor it, too. On the last test the level of copper ions was beginning to rise, so I had the fluid changed this spring.
