Fluid Change
mossman77
Just purchased a 2004 G35 sedan and would like to perform as many of the 60k maintenance items myself including changing the transmission and differential fluids. I can't seem to locate a dipstick/fill hole for the trans fluid. Do I drain and refill directly at the transmission just like the diff? Do I need any special tools for changing the fluids?
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
mossman77 wrote:Just purchased a 2004 G35 sedan and would like to perform as many of the 60k maintenance items myself including changing the transmission and differential fluids. I can't seem to locate a dipstick/fill hole for the trans fluid. Do I drain and refill directly at the transmission just like the diff? Do I need any special tools for changing the fluids?
I normally do all of my own stuff, but with the transmission, I would advise taking it to NISSAN and getting them to flush it. They will get it all out as opposed to getting some of it out.
Recently took my daughters 00 MAX. They charge 109 for the coolant and 139 for the transmission. I got them to do both for $200 out-the-door.....ask if they have any coupon books!!!
telcoman
smockers83
Car: 2006 G35 Coupe
Plus, any warranty claims that you might have regarding the transmission would need to be backed by proof that you did so...receipts of purchasing fluids doesn't count.
C-Kwik
just to confirm, you have a manual or auto transmission?
mossman77
I have an automatic transmission, and only have about 4.5k left on the warranty, so not really concerned about that. Also, I have heard bad things about flushing your transmission, and like to do my own work. I can save $100 or so doing it myself.
