Postby
rico05 »
https://forums.nicoclub.com/rico05-u8176.htmlThu Oct 16, 2008 2:08 pm
Odd issue. My speedo needle is a tad erratic. Only happens above 75. It will just kind of wobble a bit even when I hold the throttle steady.
I figured this out when I had a really cool guy in a GT-R with brand new plates play on the highway on the way home from work today. North Dallas pwns.
Postby
Liquid_Neon »
https://forums.nicoclub.com/liquid-neon-u9864.htmlThu Oct 16, 2008 4:11 pm
my pulsar is strictly cable... no speed sensor. but i know when its fluttering its usually because the cable is worn after so many years of spinning very fast... and being made of only plastic.
Maybe is the sensor fed signal by a cable or is it mount directly on? It could be the sensor itself or maybe the pickup medium it uses to determine speed?
Postby
zmannz »
https://forums.nicoclub.com/zmannz-u23244.htmlFri Oct 17, 2008 10:03 am
My old mazda b series truck did this at any speed under about 35. I eventually took apart everything piece by piece that could cause the problem and traced it to a faulty gauge in the cluster which was easily replaced by a trip to the yard. That was on a totally manual reader and readout though, it was totally cable driven.
