1991S13 »
https://forums.nicoclub.com/1991s13-u22320.html
Tue Mar 15, 2005 5:12 pm
Since you're new I'll tell you first, click Search in the upper right corner and look up what your question is, most topics have been covered extensively.
But a lot of people have the idle problem. 500 to 1000 doesn't really sound that bad, mine holds idle at around 700. The black box on the driver side of the engine compartment, the AIV valve (has a rubber hose going to it from the airbox, and another hose coming from the header), can get clogged and send exhaust through your intake, causing poor idle. Take it out and pull it apart, and clean the reed in the inside. Or, you can just take the whole thing off, plug up the lines going to it (4 if Im not mistaken), and don't put it back on. It's for emissions, but after the car is warmed up it doesn't make a difference.
Clean your throttle body too. My car was idling at like 3,000 once, so I cleaned a lot of black junk off the throttle plate and it went back to normal.
Try that and see if it affects it at all.
