Ceptos »
https://forums.nicoclub.com/ceptos-u840.html
Thu Sep 11, 2003 7:12 pm
i finished installing a set of JIC FLT-A2's on my 95 240. the install was very easy, i would recommend installing your own coilovers to anyone who is thinking about it.
they are a lot softer than i had imagined. but i like the feel. adjusting the height and position of the spring perches was a little confusing at first but it ended up working out fine.
i think i am using the 8th hardest setting on the front, and the 5th hardest on the back. right now my rear is about an inch higher than the front, tho i plan on changing this after the alignment. still doesnt seem harsh at all, i will probably stiffen up the front and back a little more.
the only thing that still has me wondering is adjusting the dampening setting, the feel of the clicks can be a little confusing somtimes, and its hard to tell where to start, its not really a clean click at the end, so im not sure if i should start there or start from the first click.
tommorrow im getting an alignment, since i have no camber adjustment pieces on the back, i was thinking of telling them to set the front at its stock extreme, one degree.
