zerothread?id=283265Hijacker wrote:I fixed my dome light by fixing my door anchors. The nylon bushing had completely worn off my anchors and the door pins/bushings were worn out as well, which gave play to the door when it was closed. I didn't replace the pin/bushing in the door, but the anchor was enough to close the gap back and fix the dome light issue.
that actually wouldn't work on the vert because of some added structure in the car...94_240sx wrote:Someone needs to make or import this. I'm interested.
